work model feed-in priority with Mode Scheduler
Hi!
First off thanks for all the useful info here, i have already learned a lot!
I have a KH9 + EP11 setup, on Octopus Agile + Fixed export
I am trying sell all PV during the day + setup cheap battery charging using the Agile functionality in the mode scheduler
When I try to set the Work model to Feed in priority it seems to disable the Mode scheduler, and if I re-enable the scheduler it resets the Work model back to self use.
Is this expected?
Is there any way to use the agile scheduler for charging battery and use feed in priority?
Cheers!
Re: work model feed-in priority with Mode Scheduler
I’m not agile mode expert but i’m pretty sure that you cannot use agile and independent schedules at the same time as they both use the schedule slots to manage the inverter and so one will over-write the other.
Do you have an EV by chance, as it’s much easier to fix your battery charging to the EV low tariff part of the day and export all your PV (using feed-in workmode).
