Stop batteries from being used.
Good afternoon,
I currently have a H1-5.0-E invertor and and 1 master ECS2900- Version 2 B type with 3 slaves. In the winter I set "charge from grid enabled" on the app to charge the batteries between 11.30 - 5.30am when I get cheaper rates which is also the same time my electric car charges. But during the summer, the solar panels produce enough charge I don't need to enable this, however, when I still charge my car at night, it is using the batteries which I don't want it to do.
Is there a way to stop the batteries form being used during those hours, but not charging themselves from the grid?
Thanks in advanced
Shane
Re: Stop batteries from being used.
Yes set the same time period, but leave the ‘Charge from Grid Enabled’ to off - that will stop the batteries from charging and also prevent discharge during the time period you s.
Perfect, I didn't see that. Thank you for your help.
