Total Grid import and Export in Kwh/day
Is there a way of finding a total figure for both Grid Import and Export in Kwh/day on either the App on ESS Cloud.
all that i can see is a graph by time and associated data whihc i can see in total /day
thanks
Re: Total Grid import and Export in Kwh/day
If you have a hybrid inverter (KH,H etc..) yes is the answer but if you have a solar only inverter the only metric is can provide is production (without an optional meter fitted).
On the V2 app, swipe left on the main 'house' page and the available stats will be shown for that day.
On the website you can see statistics (again only available to hybrid inverters) on the Inverter Details page where you see device status and energy flow, the graph at the bottom defaults to 'Power' but has a 'Statistics' tab next to it.
Thanks Dave
Yes have a KH10 Invertor
so on the website can you confirm the difference of the 3
Total Yield - Export ?
Consumption Yield 1 - Import?
Feed-In Yield 1 - ?
From the Website (for 09.06.25)
Consumption = 19.4
Total Yield = 3.1
Feedin Yield = 2.3
From App ( same day)
To Grid = 2.5
From Grid 21.4
can you give some clarify on the figures
On the website if you are looking at the Inverter Details page
'Total Yield' = All of the work the inverter has done whether through PV or battery.
'Consumption Yield1' = House load consumed
'Feed in Yield' = Exported to grid
You need to look at statistics on the Overview page for From Grid (Consumption Yield1)
The website has always been confusing (mostly because of legacy, for example PV production is a new metric only recently added it used to have to be calculated). A lot of development has gone into the V2.0 app, and that is usually the correct source for any statistic and also why Fox are developing a new cloud V2.0 website - take a look at the new website here https://www.foxesscloud.com/v2/login statistics appear correct here as well.
Thanks again for the help Dave
