Battery Constant Discharging during Force Charge Period
Posted: Sun Mar 12, 2023 9:43 am
Hi guys,
I’m a newly owner of an H1-5.0-E inverter, with 4 full black panels outputting 2160wp. Attached I have a set of CM2900 and CS2900 batteries. This set allows me to not use grid electricity from 8h to 22h. I’m very happy with the installation, however there is issue/characteristic/feature which is annoying me a lot. The battery is configured to force charge between 22h and 8h, and from 22h to 23h59 allowing charge from grid also.
The problem is that the battery is discharging all night from 0h to 8h, at a rate of 122Wh. That might sound little to worry, but the thing is we are talking about 23,9% of the avalaible capacity of the battery, being spent on the less expensive tariff period, and configured to only allow charge on that period.
Here you can see the constant battery discharge during the night at the rate of 122W per hour. Here you can find the battery force charge configurations: Am I missing any extra configuration to preserve the battery for the period 8h to 22h?
Thank you in advance!
