Data crunching questions - why?!
Posted: Tue May 13, 2025 4:43 pm
Hi there,
We have a new installation comprising 8 panels run through 2 inverters (as on FiT) and with a 5kW battery. All is running well however, I am struggling to understand some of the data the app is presenting us, and was hoping you may be able to help
1) Why does there appear to be a relationship between PV generation and load, when one goes up the other follows, etc? I didn't expect to see this. I have attached a few screen shots. Is it something to do with inverter arrangement?
2) Why do I appear to be exporting more than I am generating (no additional generating sources)? The daily stats show me generating producing more than exporting (for example PV production = 20.20kwh, 7.10 to Load&Battery and 13.10 to grid). But the graphical display shows export > generation for example 4.33 kW export against 3.1 kW generation (see attachment).
3) For Load - the graphical data shows it being consistently quite high (say 1.2 KW) but then dropping when I put on a high load appliance. You can see this in attachment where the little blips are when the induction hob went on.
Any idea what is going on?
Thanks so much
Thanks so much
