I just installed a fox 7 kW inverter recently a month ago to my house.I am living off grid and I am fully dependant on inverter for my energy necessities.I am just wondered that can I go with this inverter and batteries on 1 ton inverter AC all night without grid just on batteries.....is it possible? Or provide me solution to fulfil my need...
off grid usage
You should be able to as long as you generate enough electricity in the day from solar to cover your load and charge the batteries and as long as the batteries are scaled appropriately - ideally your batteries would be twice your normal daily usage so that you have enough power to keep running even when solar power is low.
