Where to place CT clamp to record solar output.
I have a 5kw AC1 inverter with Enphase microinverter on each panel connect to an Enphase Gateway.
I am recording grid/battery info. but not solar, I have wired the CT clamp into conns 7/8 0n the inverter.
Any help much appreciated.
You would need to wire a second CT2 to pins 5 + 6 and have the clap clips to the live output of the micro inverter and enable to sensor on the inverter under settings > feature >ct >ct2 enable.
