solar compatible EV Charger
Posted: Fri Mar 07, 2025 2:50 pm
by waiting4solar
Dear All,
Can someone recommend a solar compatible EV Charger 7kw for my Foxess system. my current one is not compatible, i had it before the solar system! :cry:
many thanks for your suggestions..
system;
13 solar panels
5.6 kw inverter
x4 batteries and master battery = 20kw
Re: solar compatible EV Charger
Posted: Fri Mar 07, 2025 3:35 pm
Most popular and highest rated are the Hypervolt or Zappi chargers - i’ve had the Zappi for over 3 years and it has been faultless and integrates well with Octopus if you want to choose their Intelligent EV tariffs.
Posted: Fri Mar 07, 2025 4:00 pm
by waiting4solar
thank you for your reply.
with the Zappi unit, wil the excess power get direct it to the car? instead of feeding the grid..
Dave Foster wrote: ↑Fri Mar 07, 2025 3:35 pm Most popular and highest rated are the Hypervolt or Zappi chargers - i’ve had the Zappi for over 3 years and it has been faultless and integrates well with Octopus if you want to choose their Intelligent EV tariffs.
Posted: Fri Mar 07, 2025 4:10 pm
Yes it has an ECO mode and an ECO+ mode and it detects how much export is available.
The minimum amount of charge power an EV will accept is 6A (~1400 watts), in ECO mode if there is more than 1400 watts export it will all go into the EV up to a max of 7.2kW.
In the ECO+ mode you can specify a minimum green level (MGL) so for example if there was only 1000 watts of spare solar it wouldn’t be enough to start charging, - you can set the MGL to 70% then the remaining 400 watts would be taken from the grid so the car keeps charging even if there are passing clouds.
