I have seen on the forum the strong advice that when using the H1 inverter one should avoid the USB port connection for attaching the Modbus. My install will have the KH 8kwh inverter which also has a USB connection. Does the same advice apply to this model regarding the limitations the USB connection imposes on parts of the data transfer. The manual states that the terminal is WiFi / 4G /USB if that is anything to go by. Many thanks for any thoughts on this.
