Random battery charges
Posted: Mon Jan 13, 2025 8:34 am
I have (in the mode scheduler), my battery set to force charge between 2 and 5 am (to take advantage of the Octopus Flux rates), and, because it's winter and I don't have a lot of battery capacity, to force charge again between 2 and 4 pm up to a maximum of 60%. This was working well for about a week and a half.
However, a few days ago, while it continued to charge at the specified times, the battery also started drawing from the grid to charge itself at seemingly random times of day: on three successive days, once at midnight, once around 8am, and once around 8pm. On no occasion was the battery close to its specified min (15%), and on every occasion it charged up to exactly 60% and then stopped. Yesterday, it then proceeded to stop using the battery to power the house entirely, and the battery stayed on 60% all day. It reverted to normal behaviour at 5 am this morning after the nightly charge.
Any clue what's going on here? Is the mode scheduler buggy? Anything to do with the cold weather (but then why exactly to 60%?)?
On a related but less worrying note, I observe that in the 2-4pm slot, the battery does indeed draw from the grid to charge up to 60% and then stop drawing from the grid to charge more. However, during that time, it won't discharge the battery to power the house at all, even if the battery is well above 60%; and it directs all solar generated to the battery as well, again, even if the battery is over 60%. I would ideally like it to revert to normal behaviour if the battery is above 60%, or at most allow a small buffer (e.g. 65%). I don't suppose this is possible?
