Latest Firmware versions for H3
Posted: Tue Nov 19, 2024 8:22 pm
by Domin2000
Hi.
Fox Ess released new Master and Manager Firmwares in early November.
Does anybody know what changes from Master 2.01 to Master 2.02 and Manager 1.80 to Manager 1.81?
Other Question: Does Fox ESS automatically updates firmware on my inverter or only if you kindly ask Fox Ess Support? I ask because today a new firmware(Master and Manager) was installed on my inverter.
Re: Latest Firmware versions for H3
Posted: Wed Nov 20, 2024 8:44 am
We don't get release notes from Fox about what the firmware contains, I have heard that the 2.0x release added some stability and the ability to set a grid compensation value - it was rapidly followed up by 2.02 and 1.81 because the way Fox calculated statistics for Grid and Export was incorrect - so this release is very much a technical update to fix the previous version and would have been done either by Fox or your installer to correct the 'broken' statistics.
Posted: Wed Nov 20, 2024 8:48 am
by Domin2000
Dave Foster wrote: ↑Wed Nov 20, 2024 8:44 am We don't get release notes from Fox about what the firmware contains, I have heard that the 2.0x release added some stability and the ability to set a grid compensation value - it was rapidly followed up by 2.02 and 1.81 because the way Fox calculated statistics for Grid and Export was incorrect - so this release is very much a technical update to fix the previous version and would have been done either by Fox or your installer to correct the 'broken' statistics.
Thank you!
