Hi.
Fox Ess released new Master and Manager Firmwares in early November.
Does anybody know what changes from Master 2.01 to Master 2.02 and Manager 1.80 to Manager 1.81?
Other Question: Does Fox ESS automatically updates firmware on my inverter or only if you kindly ask Fox Ess Support? I ask because today a new firmware(Master and Manager) was installed on my inverter.
Latest Firmware versions for H3
We don't get release notes from Fox about what the firmware contains, I have heard that the 2.0x release added some stability and the ability to set a grid compensation value - it was rapidly followed up by 2.02 and 1.81 because the way Fox calculated statistics for Grid and Export was incorrect - so this release is very much a technical update to fix the previous version and would have been done either by Fox or your installer to correct the 'broken' statistics.
Thank you!Dave Foster wrote: ↑Wed Nov 20, 2024 8:44 am We don't get release notes from Fox about what the firmware contains, I have heard that the 2.0x release added some stability and the ability to set a grid compensation value - it was rapidly followed up by 2.02 and 1.81 because the way Fox calculated statistics for Grid and Export was incorrect - so this release is very much a technical update to fix the previous version and would have been done either by Fox or your installer to correct the 'broken' statistics.
