Solar Output from Sunnyboy to Fox Cloud
Posted: Wed Nov 13, 2024 6:00 pm
Hi, I am new to this forum and wondered if anyone may be able to advise whether there is such a thing as a collar which can be fitted around the Solar output cable to allow the solar power output to be viewed in the Foxcloud/App?
We had solar panels and inverter fitted in 2016, the inverter for the panels is a Sunnyboy SB3600TL-21.
We have recently had a Fox AC1-5.0-E-G2 Inverter and Fox EP11 10.36KWh battery installed.
Because the feed from the panels is not connected to the Fox Inverter I can only see the data related to the battery, I would like to be able to see the solar output in the app as well if possible. Thank you.
