I have recently had a solar and battery install. (6kw solar, Fox inverter and Fox 8.2kwh battery). It all works fine so no problems there.
With the onset of winter, I can see that on overcast days, the solar panels will not always fully charge the battery during the day. To date, if my partner want to make extra use of the electric oven, I program the system to prevent battery discharge while it is on. To date, using this strategy, the battery has never dipped below 30%. (I have minimum SOC set to 15% and recharge the battery overnight during the off peak period).
I am considering adding an extra slave to the battery (Currently an ECS4300 master and slave) to provide an extra safety buffer and so I don't need to worry about any extra load on the system some days.
The extra slave will be the same make/model etc as the current battery and I have seen various article/videos explaining how to install an extra slave so I am sure it is well within my capability to do a safe and proper job.
The question I have is - will doing the work myself affect the system or battery warranty or do I have to get the original installer to perform the upgrade? I could of course ask the installer but the answer might well not be unbiased
Has anyone else had experience of upgrading a battery themselves and has any advice/things to watch for etc.
Regards
Phil
