Page 7 of 7
Re: EP11 with heater
Posted: Wed Jan 14, 2026 1:13 pm
by MaterialBarracuda48
albie999 wrote: ↑Wed Jan 14, 2026 9:23 am Interesting as you can see from screenshots, the min and max temps have increased
Can you test for us all please, if the start and end point have ANY form of logic testing.
What I mean in simple English, is can you set a start point of say 12°C for top setting. And will the stupid software let you set end point on the bottom as 10°C?
If it does accept this, then you might need to screenshot and send this back to get them to fix if this bug exists.
Posted: Wed Jan 14, 2026 1:17 pm
by albie999
Not quite sure I understand (me being thick) but thought the top temperature was indicating at what temperature the heater is supposed to kick in (below 9c) and the bottom temperature when it switches off the heater when it's reached that temperature (15c)?
Posted: Wed Jan 14, 2026 1:23 pm
albie999 wrote: ↑Wed Jan 14, 2026 1:17 pm Not quite sure I understand (me being thick) but thought the top temperature was indicating at what temperature the heater is supposed to kick in (below 9c) and the bottom temperature when it switches off the heater when it's reached that temperature (15c)?
I can see in your new picture that the end points have changed
The top starting temperature you maybe have set like mine is, so 9°C and end point at 15°C
I was wondering if their code is so stupid that you can set a start temperature of say 12°C and end as 10°C which is lower.
It should do a test to see if the end point is lower than the start point and reject it, but as this is Fox.... see if it accepts min 12°C and max as 10°C if you can, save and exit app, open and check values. If it takes those stupid values, screenshot and share please, and send it off to Fox also if you can :D
Posted: Wed Jan 14, 2026 1:28 pm
by albie999
To answer your question, it seemed that it took the request and gave me a "success"
Posted: Wed Jan 14, 2026 1:35 pm
albie999 wrote: ↑Wed Jan 14, 2026 1:28 pm To answer your question, it seemed that it took the request and gave me a "success"
Well damn :roll: that's a simple enough bug to see
Thank you for testing it.
Posted: Wed Jan 14, 2026 2:49 pm
by albie999
So far .. not seeing allgood results, as per screenshots below ..... it does seem like the battery is "discharging" with the heater enabled in the app ... however, it does not seem to be actually heating the battery
The increase is temp ... is when I was pulling from the battery .... tumble drier etc ..... but since the high load dropped off .. you can see the battery is cooling
Posted: Wed Jan 14, 2026 3:03 pm
by albie999
Honestly, I am going to lose it with Fox soon ... latest part of the saga below ..... is it me .. or are they just not understanding the problem at all
Posted: Wed Jan 14, 2026 3:42 pm
albie999 wrote: ↑Wed Jan 14, 2026 3:03 pm Honestly, I am going to lose it with Fox soon ... latest part of the saga below ..... is it me .. or are they just not understanding the problem at all
They are not testing things very well, as you answered above in my quirky test of setting end heater value lower than the start.
Self-use of the SoC when the battery is cold seems to not work, and something they are not getting.
Remember to put a cushion on forehead for when you bang head into the wall.
Posted: Wed Jan 14, 2026 3:48 pm
by albie999
Mate, it gets even worse lol
Posted: Wed Jan 14, 2026 4:05 pm
albie999 wrote: ↑Wed Jan 14, 2026 3:48 pm Mate, it gets even worse lol
Taken from Foxessuk's own video channel
3:45 available it may be it may be at night
3:46 of course when you hit these low
3:47 temperatures anyway so there may not be
3:49 any PV it will self consume some of
3:51 its own power to keep itself warm but it
3:53 would also if needs if it needs to take
3:55 from grid um in order to warm the
3:58 battery now
4:01 for the most part people activate this
4:03 option will do it midnight to midnight
3m 45s in roughly
Posted: Tue Jan 27, 2026 1:43 pm
by maccoylton
I am still on 1.009 on EP11 and still getting the reboot loop, specifically this happens when I am on self-use the charge level falls below 40%, heat is required, and there is a little solar, generally less than 1kw. So this is switching from battery as energy source for heater to a different source. If there is a lot of solar it's fine, if there is no solar it is fine. If I turn of my PV isolators and let it start heating from gird and then turn back on my solar isolators it's fixes it.
I am not hearing anything from Fox, ticket raised in December emailed 2 weeks ago and nothing. Anyone know how to escalate?
Posted: Tue Jan 27, 2026 1:45 pm
by albie999
maccoylton wrote: ↑Tue Jan 27, 2026 1:43 pm I am still on 1.009 on EP11 and still getting the reboot loop, specifically this happens when I am on self-use the charge level falls below 40%, heat is required, and there is a little solar, generally less than 1kw. So this is switching from battery as energy source for heater to a different source. If there is a lot of solar it's fine, if there is no solar it is fine. If I turn of my PV isolators and let it start heating from gird and then turn back on my solar isolators it's fixes it.
I was having the same fault with the 1.009, I have now been updated to v1.012 ... and the "reboot" problem seems to have gone away .. but now, unless there is PV power, the battery heating does not work unless I turn on "heat from grid" .. this has been reported to Fox, and they advised that it is with their R&D department
To get over, at least, the reboot problem .... raise another ticket and ask them to patch your battery firmware, they should send over v1.012
Posted: Tue Jan 27, 2026 5:42 pm
Let's hope that this is soon put to bed, they have dropped a ball with the battery heating FW's. Maybe mid-February they will get something sorted.
Posted: Fri Jan 30, 2026 4:12 pm
by maccoylton
They updated my EP11 to version 0.012, I think this is unreleased, will keep monitoring to see if I have further problems
Posted: Sat Jan 31, 2026 11:58 am
by albie999
Thought I would give the insulation box a try .. so my own very baic kingspan box built .. which can be easily remove in summer
