Accessing Min Cell Temperatures As Opposed to BMS Temperatures
Hi All,
Is there a way to access the min cell temperatures as a graph in either the Fox Cloud or Energy Stats app?
I have found the BMS temps and can chart that over time, but the only min cell temps I've seen is that which is displayed when viewing the battery device in the Fox Cloud app - however, that is just a snapshot at the current time, as opposed to being the ability to chart it over time.
As I understand it, it is the min cell temps that dictate the batteries' ability to charge and at what rate, so I'd like to understand this to determine my insulation needs.
I've seen from another post that is is possible to chart with Home Assistant, but I do not have that (yet)...
Many thanks!
Fox ESS
2x KH20.5 Inverters
6x ECS4800 (27.96kWh total) Batteries
34x 565kW (19.21 kW) Solar Panels
2x MyEnergi Eddi Diverters for Immersion Heaters
1x MyEnergi Zappi for EV Charging
Re: Accessing Min Cell Temperatures As Opposed to BMS Temperatures
Morning,
Just to confirm that the temp shown in the fox v2.0 app under devices>battery is the bms low cell temp. In the ES app it's the bms temp which is normally 5-10c warmer.
post in another thread contains code to access cell temperatures via foxcloud
viewtopic.php?t=590#:~:text=The%20lates ... %20do%20it.
