Balancing several batteries
Posted: Wed Nov 09, 2022 1:39 pm
by Geert
I have a Solis hybride inverter since july, and added a second LV5200 battery last month.
I noticed during charging the leds on the batteries are not the same. The master battery indicaties...40 to 60%, the slave battery 60 to 80%.
As result, the Solis inverters jumps all of a sudden from 70 percent to 100% (after a sudden rise in battery voltage)
I suspect the 2 batteries are not in balance. Anybody any idea´s how to solve this?
Re: Balancing several batteries
Posted: Wed Nov 09, 2022 1:40 pm
by Will
normally you fully charge and discharge them fully and then full again normally balances them
Posted: Wed Nov 16, 2022 10:42 am
by Geert
Hmmm....
Somehow when the batteries are empty (according Solis), I can see the main battery one led blinking, so between zero and 20%, but the other battery is between 20 and 40%.
Yesterday it jumped from 35% to 100% on Solis. And we discharged it completely over the night, it looks like we discharged almost 8 kWh?
It is a strange situation.
Posted: Mon Nov 28, 2022 11:56 am
by Will
Have you tried a full empty to full cycle and restart the inverter when the battery is full and make sure the voltage and SOC are showing correctly?
