Hi Guys,
I was looking to do Home Assistant Modbus, I've already ran an ethernet cable up there, but now when i went to plug in, i can't find which port it goes into.
I think the BMS is in the port my ethernet needs to go into, so i unplugged it and enabled DHCP on the inventor, then it complained that it lost the BMS?
Image:
Model: H1-5.0-E
Please can someone help me.
Josh
Where is ethernet port, i've got 3?
You've connected to the BMS port, which is why the inverter threw that error.
Have a read of this https://github.com/nathanmarlor/foxess_ ... o-Inverter - bear in mind that not all of these inverters actually have the ethernet port. If yours doesn't, you'll want to look into a Modbus interface. There's info about all of this in the wiki linked above as well. That said, going via the serial connection gives you a much more useful setup so is recommended even if your inverter does have an available ethernet port.
