Force Charging Guide and EV owners tips and tricks
Re: Force Charging Guide and EV owners tips and tricks
Hi, Can you tell me please how to accomplish this with the newer software for iPhone that has changed the options. As it’s getting nearer to winter it will soon be time to charge the EV overnight as apposed to the solar panels through the day and I don’t want to discharge the batteries. Thank you.
Skip62 wrote: ↑Mon Aug 28, 2023 8:18 pm Hi, Can you tell me please how to accomplish this with the newer software for iPhone that has changed the options. As it’s getting nearer to winter it will soon be time to charge the EV overnight as apposed to the solar panels through the day and I don’t want to discharge the batteries. Thank you.
The app has removed the 'Force charge' switch however if you set a time period and leave the 'charge from grid' off then it will be the same as having the force charge switch on.
i.e. If you set a time period with charge from grid switched off, the batteries will not be charged from grid, they will allow charge from solar and will not allow any discharge (not feed the house).
For Grid Charging it is simpler than it used to be as now you only have to set a time period, turn the Enable charge from grid on and the batteries will charge between that period.
If you want to charge from the grid over midnight e.g. start at 11:30 pm and end at 5:30am then you set 2 periods.
Time Period 1: 11:30pm - 11:59pm, Enable charge from grid on
Time Period 2: 12:00am to 05:30am, Enable charge from grid on
If you want to charge from the grid from 2am to 5am then set 1 period
Time Period 1: 02:00am - 05:00am, Enable charge from grid on
Dont' forget to press the first 'Save' button immediately below the time periods
I am trying to enable a 'forced' charge from the grid but the panel only 'Enable charge from the grid' and NOT 'Enable forced charge from the grid'.
How can I make this change?
If you enable "Charge from grid" along with setting a start and end time, the system will charge until the battery is full or the defined period ends. If you don't enable "Charge from grid" but you only set a start and end time, the system will pull from the grid and not discharge the battery during that time.
If you set both start and end time to 00:00, that charge period is deactivated and the system will supply demand from the battery, subject to SoC and inverter capacity.
FoxESS Modbus HA Integration
Contact Fox here
Hi Callum,
Thanks for your reply. However, as we are on Octopus Agile I am trying to force the batteries (4 off) to charge from the grid. I did set a period between midnight and 7.00am but looking at the graph on the App all I could see in that 7 hour perid was a couple of 30 minute sessions when the grid snt a but of charge to the batteries. In total less than 2kW went in! I was hoping that the batteries would be close to being fully charged.
I'm suspicious that the panel to select the charging option (e.g. Time period 1 and 2 together with SoC setting) only refers to "enable charge from the grid" and NOT "Enable forced charge from the grid". All the posts and advice refers to the 2forced" charge option.
Am I missing something?
Thanks,
Steve
Fox have changed the interface since most of those posts and guides were written, it behaves as I described above now (which is closer to the actual interface on the physical front panel of the inverter).
Separately, can I ask where your batteries are stored? Cold temperatures will cause the BMS to reduce the charging current, to protect them from harm. I think that's the much more likely cause of the slow charging.
Contact Fox here
Every time I try and set the time I get an error message "unsupported function code" how do I fix this?
pbdollman wrote: ↑Tue Jun 18, 2024 2:36 pm Every time I try and set the time I get an error message "unsupported function code" how do I fix this?
It usually means you have a schedule set, and you can't have charge periods and schedules running together.
It has been difficult recently to be sure you have disabled any schedules, I find the website is the most consistent experience.
Hi Will or anyone else,
We’ve had our Fox system (KH7 and EP11) since October last year and had a Hypervolt Home Pro 3 Charger installed on Friday. Last night the battery did not fully charge as it did not start charging until the EV had completed which was several hours late according to the force charge window that we have set.
Is this expected and is there anyway to configure the systems so that both can charge at once please? We have a 100amp fuse on our mains supply.
We have set up our batteries (using the mode scheduler in the app) to force charge from midnight to 0530 (when Octopus Intelligent Go cheaper tariff ends) and then as our EV charger is compatible with this tariff it will charge at the same time. The app doesn't seem to like a schedule from 23:30 to the next day, hence the midnight start.
We learned this weekend not to plug the car in during the daytime as Octopus sometimes schedules a car charge during the day at unpredictable times so we ended up with a flat home battery that day as the car charged from the home battery. Will has another video about integrating with Home Assistant to avoid this issue but we're only a month into our system so haven't tried that yet.
If you are using a different supplier then you might need to set up the EV charge schedule within its app to charge at the same time if they don't offer an integration. We only have an 80 amp fuse and the two batteries seem to charge together fine. I hope we're not doing anything risky!
Good luck!
New user. Please be patient!
1 x H1-5.0-E-G2 inverter with 2 x 5 panels
1 x F3000 inverter with 1 x 6 panels
4 x ECS2900-2 batteries
Installed Jan 2025
Oh just realised you've had answers in another thread!
Installed Jan 2025
no worries
I have just had a FoxEss inverter and battery system installed and wondered if you can provide updated advice about force charging the battery only, the battery and EV or the EV only overnight as I have noticed that FoxEss force charge set up no longer has the "Enable Force Charge" option as shown in your video.
I have a Zappi charger and am on the Intelligent Octopus electricity tariff.
In addition, how do I avoid the car from draining the battery in advance of the cheap rate period (i.e. I connect the car at 6pm but the cheap rate doesn't start until 11.30pm)?
Any guidance would be helpful.
This video explains a lot of the charge features.
The best thing to do to prevent the EV from draining the battery is to have the EV charger moved upstream of the fox ct by using henley blocks.
Thanks Will, that is really helpful.
Hi Will. Firstly - thanks for making the effort to post your helpful and descriptive videos.
I am using FoxCloud2.0 on an Android. It is significantly simpler (better?) than the old app.
Unfortunately, all videos I have watched about Forced Charge assume you will force charge at night. I want to Force Charge in the daytime when the input rate in very low. Where I live, the only cheap electricity is 11:00-16:00.
The reason for doing this is to supplement a small (probably inadequate) 6kW of panels.
Here is my problem - during the Force Charge, when SOC reaches 100% it essentially switches off the panels, and powers the load from the battery. I would prefer that the system falls back to Self-Use after the battery is full, so that it power the load from solar if available.
Example:
Forced charge is configured 11:00-16:00
11:00 - Forced charge starts. It is a sunny day. Battery is at 50%. Panels are producing 6kw. Solar goes mostly to Load. Grid goes mostly to Battery.
13:00 - It is still very sunny. Battery is at 100%. Panels are producing 0kw. Solar stops. Grid stops. Battery powers the load.
16:00 - Forced charge stops. It is still sunny. Battery is at 90%. Back to Self-Use. Solar powers the load.
Result - 13:00-16:00 I have lost 3 hours of solar production
Setup
mikeincairns wrote: ↑Sun Feb 15, 2026 1:25 am Hi Will. Firstly - thanks for making the effort to post your helpful and descriptive videos.
Example:
Setup
Yes this has been observed many times by users when the battery is full (or limiting charge).
What inverter do you have ?, I know that there has been an update for the H1-x-WL which stops the PV shutting down - I think a good start would be to check your inverter firmware versions Master, Slave & Manager(ARM) and refer to the firmware page on here to make sure they are up to date; if they are not definitely get them updated - and go from there.
[/quote]
Thanks for the reply Dave.
I am completely ignorant about firmware updates. Is that something I can do, or something the installer does? On some posts it says it is done by an "agent" and others it suggests it can be done by an end-user. TBH - I am pretty confused.
mikeincairns wrote: ↑Sun Feb 15, 2026 10:14 am Thanks for the reply Dave.
If you open the app, click on ‘Devices’, Inverter, then click on the serial number below the picture that will show you your Inverter firmware versions, i’m guessing they may be a bit behind - If you have the very latest firmware you may have the option in there to update your own firmware, but as that is a really new option only just being rolled out, I think you’ll have to go the traditional route and either ask your installer to update the master, slave, manager firmware (they can do it remotely), or failing that contact your local Fox support let them have your inverter serial number and they can push out the updates.
Thanks for the instructions Dave.
This is what I see in the app. No idea if "latest" is true or not.
According to this https://fox-ess.tech/firmware-release-notes/ I have the latest.
I don't know how. Perhaps it just does it automatically.
ok, thanks - yes that's the latest so it's not a firmware issue, so it'll be a waiting game to see if Fox correct it on the KH.
Might be worth raising a ticket in the app 'Me', Contact Us, Support - so you add your voice to the others experiencing the same problem.
Many thanks to those contributing to this forum.
We had the same issue i.e. PV production shutting down for the whole of the force charge period when the battery wasn't full at the beginning of the force charge period.
We updated the firmware and the problem has been cured.
We only got our panels last autumn and had noted the odd charging pattern but didn't understand what was happening until we read this forum.
When the new app (2.0) was launched I already had a forced charge schedule saved on the 1.0 app. This forced charge schedule was automatically transferred across to 2.0 app and continues to function. However, I have no idea where I can see it within the new app and how I can cancel or amend it if required. Any guidance on this would be helpful. Thanks.
