Inverter ignoring battery
Posted: Sat Sep 14, 2024 11:23 am
Having a frustrating few days with my FoxESS inverter...
In trying to solve an issue with connecting my inverter to HA I've created a new, more frustrating issue.
I'd powered the inverter & batteries down to improve wiring in the modbus connector; the CT clamp wiring was intermittently causing incorrect readings, plus I wanted to connect HA to it.
Having completed the wiring and powered everything back up the inverter is ignoring the battery and just using solar and grid. No charge or discharge to or from the battery has been reported in the app.
You can see in the image below where I powered the inverter back on yesterday afternoon and after that point it ignored the battery completely.
https://photos.app.goo.gl/YGstD7jGQjRNS9WLA
Min SOC is 10%, Min Soc on grid is 15% (I use EPS mode so this probably should be higher, Max Soc 100%.
No schedules are configured, I've never used the mode scheduler and is disabled. Values for force charge scheduled on the inverter menu show all 0s.
No errors are reported on the inverter.
These checks seem to be the most common causes of battery issues reported in the forums, which I read fully before posting this.
I've also tried another power down and restart.
There is one setting in the battery menu on the inverter called "BarPwrActive", which I've not touched as I can't find any reference to it online - not sure if this setting has anything to do with the issue, but I have changed no settings since powering down to re-wire the modbus so nothing should be any different.
#perplexed.
Inverter Hardware H1-6.0-E-G2 Version : -Master : 1.27 Slave : 1.02 Manager : 1.44
Battery master ECS2900-2 v1.011, Slaves ECS2900-2 v1.12
#perplexed.
