Code41541: The device failed to set the timer mode
Posted: Fri Jun 14, 2024 9:54 pm
by Pukka2
I am now trying to set up some alternative schedules via the v2 app but on anything I do I always get the error of “Code41541: The device failed to set the timer mode” - so I am unable to make any changes through the app
Any suggestions how I solve this
Re: Code41541: The device failed to set the timer mode
Posted: Sat Jun 15, 2024 9:18 am
That's a new one on me, I can't even find that error number in their list of errors.
Can you try logging into the website, go to the Inverter Details Pagse, and click the small blue box next to Work Model and that will take you to the Scheduler page.
The app has had a few problems of late around schedules, I find the website usually works ok.
Posted: Thu Oct 02, 2025 3:03 pm
by TonyGomm
I've just had the same problem. Firstly I went into work mode and set a discharge period. This looked fine, I logged off and checked on my iphone to see if it was set there. It was. I then went back online, logged on and when I click mode scheduler I got this error. However ten-mins later I do the same and the mode is showing fine!
There's a glitch there somewhere.
Tony
Posted: Thu Oct 02, 2025 3:09 pm
by Will
You need to drag down on the plan view to refresh the app data for the config. It's not automatic.
I show you here what I mean here
Posted: Sat Oct 11, 2025 5:34 am
by 92anton05
I don't have option to disable mode scheduler on my screen. Still getting error code if I want to submit any changes on scheduler mode.
