New battery array wont power on
Posted: Sun Apr 21, 2024 12:11 pm
Hi all.
Newb around here that enjoys content and just dipped toe in to all things solar of the fox ess variety.
currently have H1-5 hybrid inverter, combined with 10*400w south facing panels all connected to Home Assistant via usb modbus.
All fitted myself with electrician friend and all working perfectly
I recently had the opportunity to buy storage in the form of a cm2900 master plus three cs2900 slaves but try as I might I simply cannot get any life out of the master when power on.
Tried normal start up plus depleted startup using the black button but no matter I get no life from the unit at all.
I believe they should come 50% charged but is there any way to test before I ask the supplier to replace.
Supplier says not had any previous issues.
Many thanks.
Many thanks.
