Battery relocation
KevG
Hi all,
I'm looking at relocating my HV25 batteries to another area of the garage but this would require the leads from the interface to the inverter to be in the region of 5 meters. (Batt IN/OUT and PCS)
Does anyone know of a supplier that produces 5m leads to enable this?
TIA,
KevG
Unfortunately Fox don’t make a lead set beyond the standard length, and the connectors are not standard MC4 as they are notched - the good news is that you can make up your own leads using the spare terminals that are provided with the inverter/batteries (usually in the bag with the user manual), otherwise you would need to get in touch with Foxess support and ask if they can supply spares.
The not so good news is that they specify a max battery cable length of 3M any longer and they won’t warranty them.
KevG
Many thanks Dave….
