Bms Ext Fault
Posted: Tue Nov 15, 2022 11:01 pm
Good evening all
I'm puzzled by a recently occurring fault - now I think this has only started since my HA modbus connection using ethernet. Could this be related?
I'm using the standard HA settings so the quickest polling is 5 seconds (which I don't think it too unreasonable) - is there any way to tell what triggers this? I noticed in the Fox app that the battery goes offline and then a couple of minutes later it seems the inverter resets itself.
The problem is I have a EPS setup on critical circuits and so the inverter resetting switches out the internal relay meaning these circuits lose power for 5-10 seconds.
Has anyone else experienced this?
The firmware versions are
- Master : 1.48
- Slave : 1.02
- Manager : 1.45
