Not drawing from battery
Posted: Sat Feb 17, 2024 3:07 pm
by PhilipHayes
Hi everyone. First Post. I've been away for a week and when I got back home the house isn't drawing from the battery. The work model is set to self use. Is this the correct setting. Thanks in advance. Phil
Re: Not drawing from battery
Posted: Sat Feb 17, 2024 3:58 pm
Yes self use is the normal mode of operation and the battery should be feeding the house like that.
Here’s a few of the more common things that can cause this -
  • A charge period has been left in use, when not being used the charge periods must be set to 00:00-00:00 and charge from grid switch off
  • MinSoc is set too high (should be ~10%)
  • If you have been using ‘schedules’ one has been left enabled.
  • Is the inverter/battery showing an error ?
Posted: Sat Feb 17, 2024 4:42 pm
by PhilipHayes
Thanks for the reply. I will have a look at all those things. I have no idea why but it is now drawing from the battery. I expect it will be one of those issues. Will post when I find the culprit,or not
