Battery serial numbers
Posted: Fri Jan 26, 2024 2:51 pm
by Sloanyd
I have just discovered my batteries have different version number, please see screen dump attached.
Should i ask the installer to update or is this nothing to worry about?
Re: Battery serial numbers
Posted: Fri Jan 26, 2024 3:23 pm
At a minimum all the slaves should be the same version, but actually they are really old firmware versions, I would recommend you ask your installer or raise a ticket along with your inverter serial number to FoxESS and get them updated - later versions have improved capacity, temperature handling and SoC stability.
Current Mira Versions are :-
1.011 for Master (BCU) and 1.09 for Slave (BMU)
Posted: Fri Jan 26, 2024 5:20 pm
by Sloanyd
Thank you Dave,
I have contacted the installer, I will give them a week to update and raise a ticket if they dont do it.
Darren
Posted: Fri Jan 26, 2024 8:11 pm
by reef
Please let know if you see any improvements when the firmware is updated. I'm running 5x HV25s like yourself and am also on master 1.004 and have 4 batteries on 1.00 and one on 1.001.
Posted: Sat Jan 27, 2024 12:10 am
by Sloanyd
reef wrote: ↑Fri Jan 26, 2024 8:11 pm Please let know if you see any improvements when the firmware is updated. I'm running 5x HV25s like yourself and am also on master 1.004 and have 4 batteries on 1.00 and one on 1.001.
Will do
Posted: Wed Mar 13, 2024 8:06 pm
by reef
I've just been updated to the latest versions today which are now 1.013 Master and 1.10 slave. I'll report if I see any improvement!
