Idle
Posted: Thu Jan 18, 2024 12:51 pm
by casper2
Hello
Want to check if anyone else has noticed a high idle consumption.
I don't know about other batteries, but have seen these with both the V1 & V2.
It is not always so easy to spot when you have load and other things.
But have now come to the conclusion that it seems to be around 300 w if you have 8 batteries, also measured a stack with 4a and then it is at about 150w.
Anyone else notice this? Or know what causes it?
Re: Idle
Posted: Thu Jan 18, 2024 2:03 pm
by calum
What inverter do you have? I have an H1 and 6 HV2600 batteries, there is a constant draw of around 120W keeping the inverter and BMS running.
Re: Idle
Posted: Fri Jan 19, 2024 2:12 pm
by casper2
H3 12kw
Re: Idle
Posted: Fri Jan 19, 2024 3:44 pm
by calum
OK, as said, it's basically the energy needed to keep the inverter and BMS power conversion circuits energised and ready to go (mainly the inverter). It's higher for three phase equipment.
Re: Idle
Posted: Thu Jan 25, 2024 9:57 am
by casper2
Do you think that is normal?
I feel that there has been a higher base consumption after updates.
Worked with several different systems but this is above normal.
I mean roughly 7kwh every day just for self-consumption..
Re: Idle
Posted: Thu Jan 25, 2024 4:26 pm
That seems a little high, the H3 does take more than the H1.
Check your firmware versions as there was a post recently that said there was an issue with the H3 taking more power at idle that had to be corrected via firmware upgrade - i'll see if I can find it.
Re: Idle
Posted: Thu Jan 25, 2024 4:34 pm
Dave Foster wrote: Thu Jan 25, 2024 4:26 pm
I've found a couple of posts towards the end of November last year that refer to the H3 using a lot of power at standby (>200W), the correction was to downgrade the firmware - As some time has elapsed since then I think it best if you raise a support ticket with your local FoxESS service and ask them to check the firmware versions in light of your high idle consumption.
