Grid Fault on AC Inverter
Can anyone offer troubleshooting advice for Grid Lost Fault on an AC1-5.0-E inverter? I have no reason to suspect there is any grid fault - all other electrical items are functioning normally and the seperate Solis 4G inverter is not showing any grid problems.
TIA,
Stephen
FoxESS AC1-5.0-E Inverter
2 x HV2600 (5.2kWh)
Solis 4G Inverter
14 x 285W
Re: Grid Fault on AC Inverter
Likely means the foxess inverter has lost power. check the trip switches and make sure it's sized correctly. Normally a 32amp for a 5kW.
