How to remove one big load from the battery?
Posted: Thu Nov 10, 2022 11:56 am
I have 7 x HV2600's and apart from this issue it's been working OK - until I switched on my air-source heat pump on for the winter.
The heat pump is draining the battery from 100% to 10% in 2 hours - far from ideal.
What's the best way to exclude the heat pump from being supplied by the battery?
I'm guessing it will involve moving the CT clamp to somewhere other than the main tail or replace it with a meter - but I can't figure it out and haven't found any information on line. Any ideas / insights / experience would be most welcome.
