Is anyone else having issues following the maintenance work on Foxesscloud over the weekend?
Both web/app are showing pretty much zero energy use since around 4:41 this morning. Also, the battery status is blank (0%, 0 power, 0 voltage).
The battery/inverter appear to be working fine.
So, I'm guessing that either there is an issue with the cloud service or my inverter has gone offline and is not sending data to the cloud. If the latter, how do I check/resolve that?
edit: looking at the datalogger on foxesscloud shows that it has signal and has a green tick by the status, so I'm guessing the problem isn't at my end.
Thanks,
Graham
Thanks,
Graham
FoxESS AC-1-5.0-E Inverter
FoxESS ECS Series: 1x FoxESS CM2900, 6x CS2900 batteries
Lux Hybrid 3.6K Inverter
9x 320W JA Solar panels
Tesla
Octopus Intelligent Go
Tesla
Yes, I have the same issue. Battery just shows 0%.
Everything local is working fine as the Energy stats app is still showing everything other than the battery.
Same. I'd imagine it's everyone.
H1-6.0-E inverter
Fox Energy Cube 5.8kWh
13 x Evo Super Max Series 455 (5785w)
Hi ! Finally cloud APP shows only 0 for me, but devices are working correctly.
FoxESS Hybrid-WR H3-8.0-E
LiFePo4, 2,9 kWh x 3
Yep same for me, with status overview saying last updated 3 months ago...was only installed 6 weeks ago.
Mine now seems to have just updated in the last 8 minutes. Everything appears back to normal.
Mine too!
Tesla
Tesla
And off again...clearly whatever was being done over the week-end still having some teething troubles
Inverter and datalogger showing as online, but battery offline.
edit - API also seems to be completely down - had no new data since 10am.
It has been restored but there are still a few problems, hopefully not long.
Mine is still down...........??? hasn't been running all week
Both app and website are virtually unreachable. I get "error 5XX" when trying to use website and timeout after timeout error with the app.
Getting tired of second rate service from FoxESS. I've had my system 2 years and with the recent firmware update I was finally satisfied I had a great system until they broke the app and website with the recent update,
With Christmas knocking at the door I suppose I can look forward to another 2-3 weeks of flaky-at-best performance.
I'm back to thinking as I did after my installation was completed and I was given no instruction whatsoever. My installer even threw the supplied instructions out with the rubbish.
In a nutshell, "I WISH I'D GONE TESLA!"
I haven't checked in the last few days but, on logging in today on the phone app, again I'm having trouble connecting. "Failed to coonect to Foxess......etc"
Is anyone else having the same problem?
Just tried with the Fox app and Foxcloud2 both working ok, if you are using energy stats make sure you have the latest update.
Yes, still as flaky as ever. It can take up to TEN attempts to log in and I get the same messages here.
Old addage: If it ain't broke, don't fix it.
