						Help with connecting Inverter to Home network.
						Posted: Sun Nov 12, 2023 6:24 pm
						by matt24
						Hello I have a H1-6.0-E Inverter and cannot see how I get it connected to my home network. Looking online it looks like I should be able to plug it in with an ethernet cable, the only port I can see to plug into is the COM port? is this correct?
I've attached an image of the bottom of my Inverter. Any help would be much appreciated!
						Re: Help with connecting Inverter to Home network.
						Posted: Sun Nov 12, 2023 8:01 pm
						by ImAFK
						I believe some models do not have the ethernet port and you have to use the modbus to gain access sadly. I had an inverter installed that looked similar but ended up getting it replaced
						Posted: Mon Nov 13, 2023 12:09 pm
						by canton7
						Yep I have the same inverter. There's no ethernet port, you'll need to use a RS485 adapter
						Posted: Mon Nov 13, 2023 9:33 pm
						by matt24
						Hello thanks for the information, thats annoying! Where does the RS485 adapter plug into to? I don't seem to be able to find any good guides.
						Posted: Tue Nov 14, 2023 8:25 am
						by calum
						Posted: Tue Nov 14, 2023 10:09 pm
						by matt24
						Hello thank you that makes it much clearer.
Good guide!
Mini project for the weekend, thanks
