Schematic: Connection and Comms...
Hi all.
In the interests of trying to help, I thought someone may find the attached helpful with their thinking for where CTs/Energy-Meters might be placed in the chain.
I'm not an expert! Always seek advice from a competent person.
My setup includes:
  • FoxESS H1 (6kW)
  • 12kWh (ECS4100)
  • AC Connection supplying main house loads
  • Backup connection supplying "critical" loads (Lights and LOW POWER devices including IT equipment)
  • Myenergi (Eddi & Harvi): Using CT clamps
  • Eastron SDM 120/230 Energy Meters (in-line DIN)
  • Waveshare 485 devices
  • Home Assistant
Notes:
  • I have a local earth rod working with grid earth
  • All the above is in a duplex metal enclosure but segregated for AC/Backup isolation (keeps it all in one tidy space)
  • EPS on the H1 is set for UPS, with internal switching (no external load switching as I'm only doing discrete circuits - not whole house backup)
  • The "Main EM" is dedicated for the H1, and is connected to the "Meter" inputs on the H1. It replaces the need for a CT clamp and is "instant" readings for the H1.
  • I use the other Eastrons just because I'm curious and the readings are sent to Home Assistant.
I created this to work through where best to place an RCBO for an EV that I may (or may not get) in the future. I think I've got it.
Hope this proves helpful to others.
If there are any glaring faults, I'd also welcome any constructive feedback :).
Thanks.
Home Electric Chain and Comms.pdf
(152.51 KiB) Downloaded 635 times
