power from panels not as expected
Posted: Thu Sep 07, 2023 3:07 pm
by Crazy_Ivan
I'm pretty sure I know the answer to this already just wondered if anyone else has had the same issue and how they rectified it.
I have a 3.7Kw inverter, 10Kw of Mira batteries and 3.7Kw of solar panels installed, 5 on the front, and 4 on the hip.
Normally on very sunny days like today at their peak my panels would generate 3.6Kw at their max when the sun was in the right position.
Last saturday the peak was 3.3kw - pretty good, now over the course of the week with the dry spell we are having the output power has slowly started to drop peaking at 2.6kw today - I am assuming there is a layer of dust of the panels which is hampering their performance, as this is all over my car as well.
Has anyone else noticed this and is there anything I can do besides the obvious of aiming a hose at my roof and cleaning them off?
Cheers
Scott
Re: power from panels not as expected
Posted: Thu Sep 07, 2023 8:23 pm
by Ched
Don't use your hose as the calcium and/or magnesium dissolved in water will dry on your panel and cause 'water marks'. Much better to wait for the rain to wash off the dust.
It's good practice to have them cleaned once or twice a year. A decent water fed pole window cleaner should be able to clean them from the ground as they use pure water.
Posted: Fri Sep 08, 2023 7:51 pm
by calum
Looks like we're due some sharp showers next week which should sort things out.
Where I am (SE Manchester) the water is from the Peaks and pretty soft, so if we had a long period of dry weather I wouldn't feel too worried about rinsing them down if needed, but if you get limescale in your kettle etc then definitely don't do that!
Posted: Sat Sep 09, 2023 10:11 am
by reef
The last few days reduction has been due to saharan dust in the atmosphere rather than anything on the panels. I have a weather station and it has recorded solar insolation maxing at about 600w/m2 vs around 800w/m2 that would be expected at this time of the year. This is with a clean sensor too as it's at a level I can reach.
I've seen a similar approximately 20% fall in the peak on tge solar PV, reaching at most about 3.6-3.8kW from our 4.8kW system.
Posted: Mon Sep 11, 2023 5:46 pm
by Wolfenden12
Aw thanks! Since that dust shower (Chorley) my panel production has dropped dramatically! Despite rain last night and today the yield is showing as a measly 90w!! Presuming the rain will just do its thing over the next few days?
Posted: Tue Sep 12, 2023 11:45 am
by calum
From what I can see of my panels, here in Stockport we've had plenty of rain to wash off the dust, but of course now we're under a good bit of cloud.
