Regret upgrading to latest firmware
Posted: Sat Nov 28, 2026 2:37 pm
by loofer
So upgraded my Master and Manager yesterday on my H1-6.0-G2-WL
Not sure which was done in which order but the second one failed on first attempt but then successfully updated on 2nd attempt.
It’s effectively bricked my 2x EP12 batteries. Well, not completely bricked.
My force charge/discharge schedules don’t work. It’s like they don’t exist/trigger.
I’ve switched off batteries and inverter and left it for over 30 mins before switching back on. The battery lights are steady green, reflecting the SoC.
The inverter screen is on normal and communicating with inverter.
I’ve deleted the work mode schedules and recreated them. Still hasn’t worked.
The battery SoC is slowly dropping (probably due to keeping warm)
I’ve contacted Fox Support but thought I’d see if anybody else had a similar issue.
Battery parameters
Battery parameters
Work mode schedules (time and SoC within parameters)
Home Screen
Home Screen
Latest firmware versions
Re: Regret upgrading to latest firmware
Posted: Sat Nov 28, 2026 2:49 pm
by daveg
These look to me like the production latest firmware versions from Will's spreadsheet
07/08/2026 Inverter H1 Gen2 WL Master 1.59 Production (Latest)
07/08/2026 Inverter H1 Gen2 WL Manager 1.45 Production (Latest)
30/09/2026 Inverter H1 Gen2 WL Slave 1.04 Production (Latest)
Looks to me as if you've been used as a 'Tester'.
Doesn't really seem acceptable in my opinion the way Fox does this.
Asking them to roll you back seems to me the right thing to have done.
By the way, you only seem to have forced discharge set up in your schedules. I assume you've tried a force charge schedule?
Posted: Sat Nov 28, 2026 3:09 pm
by loofer
daveg wrote: ↑Sat Nov 28, 2026 2:49 pm These look to me like the production latest firmware versions from Will's spreadsheet
Thank you DaveG.
I did look at Will’s post and genuinely thought maybe he just hadn’t got round to updating it.
Bit surprised I’m using a test one. Nothing anywhere said it was and I don’t think I’ve signed up to check that I have enrolled in any Beta programme. Where can I check.
Yes tested force charge too at the time and also as my standard overnight work schedule. Sadly nothing. Meanwhile my battery limps away keeping itself warm :(
Posted: Sat Nov 28, 2026 3:22 pm
by daveg
It just seems to me that their way of testing firmware upgrades is to roll it out to a few folks and see what comes back.
I've been given upgrades to versions that were subsequently withdrawn, but they didn't automatically roll me back.
I'm not aware of any formal beta programs either.
They don't even issue any release notes so you can check whether you want whatever the upgrade is offering.
Hence my view that the way they do this is unsatisfactory
Posted: Sat Nov 28, 2026 3:29 pm
by loofer
daveg wrote: ↑Sat Nov 28, 2026 3:22 pm It just seems to me that their way of testing firmware upgrades is to roll it out to a few folks and see what comes back.
Very poor.
That will put me off doing any upgrades in future.
Not sure why I jumped at this one.
Even with iOS, I wait a few days just in case there’s some noise from those that have updated.
Posted: Sat Nov 28, 2026 5:20 pm
by MaterialBarracuda48
You have 1 picture showing the house, it has no PV, no load, no battery & grid use.
Has this changed since earlier image as you should see grid & load at a minimum?
Posted: Sat Nov 28, 2026 7:01 pm
by loofer
MaterialBarracuda48 wrote: ↑Sat Nov 28, 2026 5:20 pm You have 1 picture showing the house, it has no PV, no load, no battery & grid use.
Never had anything showing for grid (no CT clamp, so known issue)
No solar but do have 3rd party solar (SolarEdge) with CT on that.
Not sure what time I took that screenshot and ofcourse it was a very dull day but otherwise, yes it does show 3rd Solar
Posted: Sat Nov 28, 2026 9:08 pm
ah fair play
