Forced charge mode, but still draining battery
Posted: Fri Nov 27, 2026 11:14 am
I'm a new customer of Intelligent Octopus Go, and therefore have cheap electricity from 2330 through to 0530 overnight.
I used that to charge my EV, and also wanted to charge my home battery using the cheap rate. So I set mode scheduler to forced charge for that period (I had to do two separate intervals to enable it to cross through the midnight barrier). But what happened was that it drained the battery first to charge the EV; then once the battery was drained, it then pushed all the available electric into the EV until the EV had reached its set capacity (50%). At that point, it stopped charging the EV and then started charging the battery.
So the battery was up to 100% this morning, which was fine. But on some occasions, I'll want to charge the car all the way through the cheap charge rate. Which would mean that there's no further time to charge up the home battery if it's drained itself, and I'd start the day on 10% (minimum charge).
Is there a way to set the schedule to allow the home battery to charge only, but not discharge during that period? I can't see an option for this in mode scheduler?
I've attached a pic of the schedule I've set, in case I've done something wrong
