export/import/export/import
Posted: Fri Nov 27, 2026 9:52 am
by davidwf15
I am sure this has been asked....
Today we have zero solar generation so are running from battery.....why does my system continually show I am exporting then importing
Re: export/import/export/import
Posted: Fri Nov 27, 2026 11:23 am
by MaterialBarracuda48
Check a few things...
battery temperature
mode scheduler to see what is programmed
meter compensation setting
Inverter lost the plot, if the above look good, so perform a reboot.
Posted: Fri Nov 27, 2026 12:00 pm
by davidwf15
Battery temp not an issue as battery is inside...min battery temp 19.5
mode scheduler
I did noitice some firmware updates so have now installed them...maybe, like windows, it does weird things if updates are available but not yet installed....
Slave now 1.03
Manager now 1.72
Master now 1.74
meter compensation setting .... set to 30W continuous export
Posted: Fri Nov 27, 2026 12:34 pm
Yeah that all looks good on paper as we say, nice warm battery, schedule seem fine.
Hope the firmware upgrade works it's magic, I have a bug with heater controls when testing... it warms up, but no animation shown, just 'Standby'
It does spend 99.9% of the time disabled, as I have no issues with charge/discharge rates.
p.s. Thanks for the heads up, applying those FW updates now. As long as the smoke stays inside the box, all will be well.
