AI use and Battery Charging weirdness since update?
Posted: Thu Nov 26, 2026 10:07 am
I've been using the AI (Dutch user here) since a while now and as of one the latest updates to the software and firmare I can't shake the feeling something's off
Although, it could be surely my lack of understandig
What happens is the following; The AI sets it's own Scheduling tasks and I can see in the forecast section it will be forced charging by import from the grid somewhere between 7 and 8 am for example. So, when it's that time. It says it's charging as said BUT the battery is ZERO charging...at least, that's the way it looks. I do see it does something and charges a bit but I think it's a very very small amount of power it's charging by. So when forced charging overnight for a few hours my SOC only went up by a few percent... I would expect it would charge by at least a few Kwh's!
Now, I thought I saw something in scheduled task mode, if you would use that, there's a option for a percentage cut-off? Not really sure what that does other then charging less?
Anyway, does anyone know why the system wouldn't charge enough so I have a few Kwh's at hand for more cheap than I would when starting the early morning (getting up etc) ?
I do think they've improved the app considerably and it has more clarity now but I would really like to see more control and insight as to what the AI is thinking or doing...it's a bit weird to me
