Erroneous cloud data for grid import (okay on modbus)
Posted: Tue Nov 24, 2026 10:03 pm
by JoWilson
I've noticed some oddities in the cloud data in the app and cloud portal, specifically the grid import trace, where it goes flat for extended periods of time. I think this also throws off the daily totals, though I haven't been able to check that in detail yet. As far I can see this has only started occurring since 12th Nov, and there is no obvious correlation with specific times or events. My kit is as described in my signature below, installed in March, and all on the latest firmware. Up until 12/11 I hadn't noticed any problems; now, this occurs about once every day or two for several hours at a time.
Looking at the data via Home Assistant, interestingly the data from the cloud matches that in the app and portal (i.e. erroneous), but the data acquired via the modbus integration appears correct.
I also noticed that when it does this, the entity Solar Power goes wild, broadly matching the data missing from the Import entity (implying that one is calculated using the other, I guess). The entities PV Power, PV1 Power and PV2 Power look sensible, however.
Can anyone shed any light on what might be causing this and how to address it?
Thanks very much,
Jo
