Octopus Cosy
Posted: Tue Nov 24, 2026 4:08 pm
by Manor2
I am currently running the Cosy tariff, it appears when on forced charge as soon as I hit my charge target the battery starts running down to feed my consumption, as an example my force charge is set at 98% today my forced charge time was between 13:00 and 16:00, I checked the battery status at 15:00 and it was at 97% at 15:40 however the battery had already ran down to 75% and was discharging even though it should have been charging for another 20 minuets.
Any help with settings appreciated.
Re: Octopus Cosy
Posted: Tue Nov 24, 2026 4:53 pm
by MaterialBarracuda48
You want to set the value in red box to either 'Backup' or 'Standby' to have it hold the 100% SoC until the time period ends. Repeat this for the other Cosy schedules too (if needed)
I will explain what it does now, it charges during the time specified by you, once it reaches 100% it changes work mode to whatever is in the red box (probably 'Self-use') so this is why it begins to drain power before it reaches end of your schedule.
Re: Octopus Cosy
Posted: Wed Nov 25, 2026 1:44 pm
by Manor2
Thanks for advice working now
Re: Octopus Cosy
Posted: Wed Nov 25, 2026 1:57 pm
Good to hear.
