only 1.5kw charging
Posted: Tue Nov 24, 2026 11:53 am
by DavidAllanCowan
I have 2x10kw batteries with heating. Charging overnight on an ev tarriff. I only get 1.5kw charging. Any thoughts? Temperature down to freezing last night.
Re: only 1.5kw charging
Posted: Tue Nov 24, 2026 5:02 pm
by MaterialBarracuda48
Several reasons it could be, either your Inverter has decided to change the Import limits (via firmware update/Fox adjusting settings) Verify Import value is high enough in the mobile App -> Quick Launch menu.
The other classic this time of year, is the batteries were so cold that the BMS refused to charge any higher than 1.5kW (or was doing an emergency charge)
Take a look here viewtopic.php?p=19593#p19593 to see how to filter items in the App, look at the last image in particular as you can see 'Min Cell Temp' and 'InvBatPower' this can show you if the batteries were too cold (aka evidence you can see)
Posted: Tue Nov 24, 2026 6:28 pm
by DavidAllanCowan
OK I am even more puzzled.
Minimum cell temperature went from about 0 to 5C
on the quick settings the import limit is 5k
Thanks again for your help
Posted: Tue Nov 24, 2026 7:01 pm
by Entwood
Have a read of this topic, might give you some answers regarding the temp being so low.
viewtopic.php?t=3838
Posted: Tue Nov 24, 2026 9:12 pm
DavidAllanCowan wrote: ↑Tue Nov 24, 2026 6:28 pm OK I am even more puzzled.
At around/below 3°C the BMS may perform the emergency charge that you see, where the rate is severely limited, or the BMS wouldn't allow more than 1.5kW of charge power. As it heats up, the emergency charge will stop (if that was what occurred) or the charge rate will increase as the Min Cell Temp rises.
Check to see if you have heater controls by watching the video, and can activate them... if not you may not have heated battery, or your inverter and battery might need firmware updates to allow it to function.
https://www.youtube.com/watch?v=_9hNCI1bTP4
If you need more help, let us know what Inverter you have and what battery also.
