Battery discharged overnight. Please explain this!
Posted: Sat Nov 21, 2026 9:42 am
by JohnH
Would appreciate some help here. I set a force charge to my home battery from midnight to 0200 but this didn't activate. I probably left the 'set charge from grid' setting as disabled by mistake which I've done before. However from 0200 the battery discharged steadily down to its 10% minSOC. Weirdly I cannot see where this has gone - the battery was at 47% at midnight so it has discharged about 5kWh when the app shows only 0.9kWh consumption and no grid export. Car charger was not plugged in.
I did see that there was an app update last night so does this have anything to do with it?
Thanks.
Re: Battery discharged overnight. Please explain this!
Posted: Sat Nov 21, 2026 12:47 pm
by MaterialBarracuda48
It won't have been the app update that caused this, but depending on your inverter there has been firmware updates pushed recently that could have broken settings.
Posted: Sun Nov 22, 2026 12:23 pm
by JohnH
Thanks. Everything OK last night with a forced charge so fingers crossed it doesn't happen again.
Still have no idea where the 5KWh disappeared to.....
Posted: Sun Nov 22, 2026 2:58 pm
by AndrewH
Maybe you have intermittent load left on? a few days ago the battery was steadily discharging much faster, yet load graph on FoxCloud showed nothing. As I have home assistant with 1 second intervals recorded, I could see the home assistant load graph was 'hazy' for several hours, rather than a well defined line. Zooming in I could see a load of 3kW for a few seconds, then it was disappear then a minute later or so would repeat. As it was off far more than it was on, it didn't show on the 5 minute graph. I eventually found the iron ha been left on for hours! I turned it off an everything returned to normal! I can imagine intermittently switching between 3kW and a few hundred watt drains the battery more than a sustained draw as it's starting and stopping all the time over a large range, but maybe not too.
