Force Charge questions from a newbie grateful for help
Posted: Tue Nov 17, 2026 6:41 pm
Hello, I'm still getting to know my system. I've searched this forum and videos and adjusted my settings as advised, but still have some questions. This is my setup:
5kw Fox H1 series (G2) inverter
10kw Fox EP11 battery
12 x 455kw panels
Heat Pump supplies my heating & hot water
Current tariff is Octopus Flux Import. During the 2am-5am cheap period, I force charge the battery and also heat my water tank (once daily does me fine). I also run things like a de-humidifier, dishwasher, washing machine etc (if there's no sun forecast) during this period.
QUESTION 1: Can the above be scheduled to all run consecutively at 2am, or do they need to be staggered?
QUESTION 2: There is a heater in my (externally mounted) battery - once it gets colder and starts to kick in, does this need to be turned off during the force charge period or both functions work at the same time?
QUESTION 3 : Is there a weather compensation setting in the Fox app, so that the force charge doesn't activate if the following day is likely to have plenty of sun to fill my battery?
QUESTION 4 - On cloudy days, my LX needs drain the battery by late evening, so I'm back on the grid. Given I have a HP, is this to be expected for this size battery or do I need to hunt for why its happening? I was led to believe the battery it should meet my needs. (HP is set on constant temperature 24/7 as I was told this was the most efficient. House is well insulated).
QUESTION 5: Given all the above, do you think this force charge setup on Octopus Flux Import is best for me, or should I look at switching to a different tariff that is compatible with Charge Pack?
Thanks so much in advance for any advice.
RubyRoo
12 x 455kw panels
RubyRoo
