Forced charge from midnight until 16.00hrs
Posted: Sun Nov 15, 2026 3:12 pm
by Metalman
I am on Octopus Agile but neither the app nor the website will authorise my account and API key. Very frustrating but life's too short to battle it. So, with the shocking prices after 16.00hrs I want to charge my batteries at night and prevent them from emptying during the day until 16.00 hrs. I have set forced charge from 0.01 to 15.59 hrs and then self use from 16.00 hrs. Is this correct? seems daft to have forced charge for so long, will it shorten my battery life?
Metalman
Re: Forced charge from midnight until 16.00hrs
Posted: Sun Nov 15, 2026 4:24 pm
by MaterialBarracuda48
Holding 100% SoC for that long, yes expect cell damage and to shorten overall lifespan.
If Agile is proving to be too much of a problem, I know as I left that behind... you have either Octopus Go (if they don't still check for EV details) or use Octopus Cosy, so you get 8hrs total electric at half price.
Here is what you can do with Cosy Tariff, note you can charge it right up to 16:00 and your battery only has to cover you until 22:00
Posted: Sun Nov 15, 2026 4:36 pm
by Metalman
Ah thank you very much. Ill look into it now
Much appreciated
Posted: Sun Nov 15, 2026 4:42 pm
I just looked at the Agile rates for the past few days, glad I left that Tariff.
Far too risky for my appetite, and locked into Cosy for safety.
Posted: Mon Nov 16, 2026 10:37 am
by Metalman
MaterialBarracuda48 wrote: ↑Sun Nov 15, 2026 4:24 pm
Sorry to pester.
Please can you explain why you only charge to 40% on early and later price dips?
Posted: Mon Nov 16, 2026 12:32 pm
Metalman wrote: ↑Mon Nov 16, 2026 10:37 am
Sorry to pester.
A few reasons really, originally I was using a portable air con unit to heat up the room we are in, but this does leave the rest of the house colder of course. I decided to remove this install (pipes out of window) and just use normal gas central heating this year.
The idea was to use the AC unit heavily, and this would need battery to be charged up to 100% for each cheap period. So now I am not using that now, I don't need that much energy daily.
So I just have it charge (if needed) to 40%, this allows the washing machine to run in the morning, and heat pump tumble drier fine from this level of SoC. The 22:00 to 23:59 charge is in case we have a shower at that time, to make sure there's enough to run the house from the cheap rate electric until the morning top up.
The morning 40% is also used to give it a head start if there is some useful PV kicking about, this on a sunny day is enough to get to 100% without the afternoon charge.
In case of a dull day, with very little PV, the latter 100% charge allows cooking in the evening peak prices to come from the battery fully, and no worries about the battery going flat.
Given how the FW/program slots work, if you reach 22:00 with above 40%, then no charging occurs, by morning the battery might drop into the 3x% range, so just get's a little morning top up.
And the main reason is keeping the battery at 100% for too long, does damage cells over time, so one charge to 100% is better than 3 (unless you need that sort of daily energy)
Posted: Mon Nov 16, 2026 3:37 pm
by Metalman
Ah ok Thank you. I will change mine to 60 100 60 then. We have two ASHP and car with virtually no Solar this time of year. I am grateful to you, I hadn't heard of Cosy until you mentioned it. We changed to Cosy today. Agile was great in the summer with lots of Solar, we even got paid to charge the car on a couple of occasions but 68p/kwh recently has made it untenable. Being able to set charge times on Fox made Cosy way more economical than Intelligent GO.
I am much obliged to you.
many thanks
Andrew
Posted: Mon Nov 16, 2026 4:50 pm
No worries Andrew, and with the SoC values, you can adjust your 60%/100%/60% split up and down as needed.
Glad to have helped.
Posted: Mon Nov 16, 2026 4:59 pm
You may also benefit to have it 'hold' the SoC you specify too, so that it doesn't discharge the battery during the cheap slots.
Highlighted in red here, make sure this is set to 'backup' or 'standby'
Posted: Mon Nov 16, 2026 6:53 pm
by Metalman
Ah great thank you, I did wonder if this was possible...
many thanks again!
