Min SOC
I noticed last night my SOC was down to 6% and the battery was being charged by the grid despite being outside my charge window, once it it had got back to 10% SOC the grid charging stopped, it did not start again until 12:00am ( Planned charging start time ) has anyone else noticed this ? and is this an issue
Re: Min SOC
Min SOC is 10% however when no solar is being generated and the battery is at 10% it does quietly continue to drop below this although not directly feeding the home. Mostly to feed the inverter. There is a hard coded safety backup in place whereby when it reaches 5%, it will automatically charge the battery up to 10% from the grid in order to protect the battery. This is normal behaviour.
Solar Panels: Aiko Neostar 3S 475W All Black ABC N-Type Mono × 18
Inverter: Fox ESS KH 7kW 1ph Hybrid Inverter
Battery: Fox ESS EP6 Plus 5.76kWh Li-ion Battery w/ heating function
Re: Min SOC
Thank you for the very quick reply, it’s good to know this is normal, I guess this has happened many times but yesterday was the first time I’d checked the app at exactly the right time.
Re: Min SOC
I had my system installed in the summer and noticed my battery down at 8% one morning which rather freaked me out as I was under the impression the 10% was a hard and fast value. I contacted my installer who advised me of the 5% true minimum with the unscheduled charge back up to 10%. I didn't see the recharge happen though until more recently when the longer nights mean more time for the battery to trickle down to 5%.
