FoxESS installer account
Posted: Sun Nov 08, 2026 3:39 am
by aibegee
I'm in the process of authorizing my PV system as a prosumer and the authorized electrician I'm working with now will install and commission the FoxESS inverter I bought - it's a FoxESS S3000-G2
The authorized electrician asked me if he would require a special (installer/admin) account for the inverter setup. I did some research, found out that there are some resellers that provide such an account (not in my case) and stumbled upon a registration page at FoxESS:
https://fox-ess.tech/how-to-create-a-fo ... lers-only/
Does that process require some uploading of certifications or authorizations?
Furthermore, in the inverter manual - file: FOXESS_EN-S Series (G2)-Manual-V1.3.pdf on page 20 I've found the following chapter:
5.9 Inverter Start-Up
describing some steps to start the inverter. However, at the very end of that chapter it states - quote:
"Note!
Please set-up the inverter if it is the first time to start-up. The above steps are for the
regular start-up of the inverter. If it is the first time to start up the inverter, you need to
carry-out the initial set-up of the inverter."
I'm confused now, since I couldn't find a section or chapter describing the so called "initial set-up". Are there any other documents I need to get and provide the authorized electrician with?
Please advise.
Thank you in advance.
Re: FoxESS installer account
Posted: Sun Nov 08, 2026 9:25 am
You can create an agent or installer account, each gives you more access to the settings of the inverter, there is no special requirement when selecting the account - normally your installer creates an installer account and then creates you a user account which allows full day to day control of the inverter, but many users have installer level.
On the setup, the essential thing to setup is safety when you first power on, that will select voltage and frequency ranges that are mandatory for your locale, thereafter it’s simply a setup checklist and the assumption is your installer has the knowledge to do that (its simple enough). Fox will provide support if there are any issues you can’t resolve.
