KH7 Grid Consumption Today incorrect but Grid Consumption looks right
Posted: Sat Nov 07, 2026 10:12 am
by Moongrazer
I have an odd discrepancy in the readings coming from my KH7 inverter (up to date firmware): my "Grid Consumption Today" is tracking lower than it should be. But, the live "Grid Consumption" (from the CT clamp) looks to be correct. I only noticed this at all because I imported overnight for the first time two days ago, and my Octopus account reported a higher energy use than I was expecting.
I went digging in my Home Assistant data and turned up some interesting results from the overnight import:
The power stats are what I'd expect: Grid Consumption overnight is tracking at Battery Charge + Load Power.
The cumulative energy stats however are not. You can see Battery Charge Today tracking at more than Grid Consumption Today, which shouldn't be the case.
I'm at a loss to what's going on. The system is recently installed, so I'd accept that maybe the CT clamp isn't the correct one - but the fact that the live CT reading seems correct has me confused! Any ideas?
EDIT: I ran an integral calculation over the "Grid Consumption" data and the total is 17.6kWh. Octopus says I imported 17.89kWh, which is about 1.6% difference and within a CT clamp's typical margin of error. The inverter's own Grid Consumption Today for that window comes in at 14.8kWh - considerably under!
