PQ1 and Home Assistant local control
Posted: Thu Nov 05, 2026 7:17 pm
I'm a fairly advanced Home Assistant user, considering buying a PQ1 with solar, battery and house backup. I've previously owned a GivEnergy system with similar capabilities, using its internal WiFi for Modbus over TCP.
What's the recommended route for local control of the PQ1 with Home Assistant? What's best in terms of connectivity hardware / addons etc? I can run cabling if required. If it makes any difference I'm capable of soldering, programming ESP32 with PlatformIO etc., although I'd rather save effort if I don't need it to do what I need.
I want HA services/entities that give me full, real-time local control of all aspects, as well as monitoring of key parameters including house power, battery power, PV power and inverter/battery temps. Creating my own automations is not an issue.
Thanks in advance for any guidance.
Kind regards
Jonathan
Kind regards
Jonathan
