FoxESS S-Series S3000-G2 Home Assistant Modbus integration
Posted: Thu Nov 05, 2026 6:39 am
I just ordered a FoxESS S3000-G2 inverter and a WaveShare Industrial Grade Serial Server RS232/485 to WiFi/Ethernet Modbus MQTT Gateway in order to integrate this inverter with Home Assistant.
Apparently I made a misguided decision, as it turns out that the Home Assistant modbus integration doesn't really support the S-Series inverters - see:
https://github.com/nathanmarlor/foxess_modbus
Please advise if there are any other modbus integration projects I should try.
The location I'm planning to use this inverter is remote and I do only have partial cellular (4G) connectivity, therefore a cloud integration is useless. I only need to check and read the AC output power of the inverter in order to start/stop appliances (heating/air conditioning & co) that are already integrated in Home Assistant.
Thanks in advance for any help/advice.
