Data Logger
Posted: Wed Oct 07, 2026 5:54 pm
by spiral
What does/should the data logger log?
My logger appears in the app but every day shows "no data"
Software version 2.05
Re: Data Logger
Posted: Wed Oct 07, 2026 6:07 pm
by MaterialBarracuda48
It logs pretty much what you see in this video from Will, https://www.youtube.com/watch?v=PrpOM05_KmU
There maybe more added to the list since the video was made.
It sends this data to the Fox servers (cloud) so that you can retrieve them to look back at values.
FoxCloud2.0 App pulls this data from the cloud to present parts of it to you.
Re: Data Logger
Posted: Thu Oct 08, 2026 12:49 pm
by spiral
Thanks for that video link. It was very interesting and I've learnt something new, but I'm not sure how it relates to my question.
I'm talking about the data logger that appears on the devices screen in the app.
If I click on it then click on network type, I get to a screen titled signal strength curve- date - statistics and it always shows no data for every day since my install. Presumably it should have some data being logged.
I can also see it listed on the website although if just accessing it here, you're not presented with a no data scenario so maybe its just obsolete.
Re: Data Logger
Posted: Thu Oct 08, 2026 1:08 pm
I may have got the wrong end of the stick, I have a W6 logger and I can see past Signal Strength Curve.
Perhaps you have a different logger, and it doesn't save/show this data to you?
Re: Data Logger
Posted: Thu Oct 08, 2026 3:19 pm
by spiral
On web interface it says it is type WW if that means anything. A quick google seems to indicate it's the main data transferrer for real time and historical data via the fox cloud so as I can see all this, it is undoubtedly working. Just raises the question then as to why there is a link to the logger via the app which records "no data"
Re: Data Logger
Posted: Thu Oct 08, 2026 3:39 pm
I guess the App having the signal strength exists for those loggers that can log this.
My W6 definitely has it, perhaps WW doesn't as you are seeing.
Re: Data Logger
Posted: Fri Oct 09, 2026 10:12 am
by spiral
Yes I suspect that is the case. I had a play with some of those settings from the Youtube video and found there are many of those that appear with "no data" also. Thanks for the pointers anyway.
Re: Data Logger
Posted: Fri Oct 09, 2026 11:07 am
Unless you want to purchase a W6, then I guess you will never know (unless someone with WW posts?)
Some of the data on the cloud won't exist, as it has values for 3-phase inverters for example R S T phases if I remember the naming correctly. Anyhow, at least you know a place you can view more information now, if nothing else.
