Changing Battery graph from % to kWh
Posted: Thu Oct 01, 2026 3:03 pm
by PeterPuttock
Hi! I am a relatively new user. I am loving the manual management of Octopus Flex using FoxCloud 2.0.
A quick question.... Is there a way of changing the vertical axis legend/data in the battery analysis graph(s) so it shows kWh's and not %?
Many Thanks
Peter
Re: Changing Battery graph from % to kWh
Posted: Thu Oct 01, 2026 7:01 pm
by MaterialBarracuda48
Hi Peter,
Not that I have seen so far.
What does exist, is you can click on the battery on the 'home' screen (or Device at bottom of screen) and click on your Battery, it will show a SoC % and 'Remaining Energy' kWh
Posted: Thu Oct 01, 2026 9:36 pm
by PeterPuttock
Thanks for the reply. I knew of the solution of looking at the battery data, but was trying to save having to transpose, say 50%, to 11.5kWh!
Thank you for answering, I appreciate it!
Posted: Fri Oct 02, 2026 9:15 am
For my EP11 each 10% is (was) roughly 1kWh, so that was easy to convert on the fly in my head
Even so, you can do rough calculation as well, so 45% = 4.5kWh (or could be 9kWh if you had around 20kWh)
Just remember that you have the total battery capacity, but usable is 10% less (as you can only use 90% due to 10% reserve)
